mike calabrese
- Finger Lakes region New York State
Given my recent success with spinning things made of wood I may be getting out over my skis a bit with this one..
The pictures here are the current attempt to build a staved bowl. This is the lower portion only, 12 staves in maple, with sapele, maple and black veneer pieces. The plan is to build a feature ring of epoxy resin and top off with some more maple and sapele.
So far it is going OK . Learning to cut the staves I have kind of come up with a method to cut the staves that seems to work for me using a cross cut sled.
In brief I simply mill up the required maple blanks for the staves . On one blank I try to lay out careful pencil lines of the double taper blank. From there the first blank is carefully clamped down and cut on the sled. The layout happens on one blank only and when cut is confirmed good stop and register blacks double taped to the sled are added before the stave is moved. Each successive blank then can be is located exactly the same against the stop and register pieces. The second cut is done the same way with the register and stop blocks reset for cut no 2 . Couple pics of that process here also showing the first cut process.
Keeping my fingers crossed too often I get too happy with the work before it really is "the work"
calabrese55
calabrese55
