Stu, I liked-ta-died doing it! It was not my plan to do it until October when it cooled down. But I'm giving notice at my current job on Tuesday, and it was either now, or lose the vacation time and wait a year until I get vacation time at the new job. So now it is...er was.
But it's done and the grounds are cleaned up.
Probably should clean out the gutter still. But, that's no fun. LOML can't see up there ayway.
I started planning out the router table this morning and listening to my favorite radio station in the shop. Very relaxing. I've decided to adapt 4 legs I built many years ago at the other house so I could stack a dog crate on top of another crate because space was so tight (15 X 12 master, with King bed, 8' dresser and 3 1/2' chest, and 1 night stand. That's changed in the current house. MB is twice as big!) So I've had these legs in storage.
They are a little short, but I'll extend the top with some Oak veneer plywood, and maybe cut in a shallow drawer on either side of the router chamber for template storage. We'll see. First I'm going to make the frame and get the Herc-U-Lift mounted, with the stretchers top and bottom, then I'll go from there as to how to finish it out. Nothing will be glued together until I get the rest of it built, so it can all be changed. The legs should be sturdy enough...4/4 Oak, glued and screwed into an L shape, with a 2X1 1/2" block 3" long glued and screwed into one end of each. This will get drilled out for the levelling feet and T-nuts. The base will be roughly 32 X 39, and the top when added will be 36 X 48. Yeah, that's big, but I'll be using (have had for 3 years already) the Incra 25" LS Posititoner system. It needs 18 or so inches from the back mounting base to the back of the fence. And I want some space out in front of the PRL lift. Most tables only look to have about 6" from the front of the lift plate. I should have about 14.
Oh, and yesterday I got the tops attached and the ducting dry fitted through the hole, and the foam isloator installed around the pipe. It shows in the picture above showing the leg.
Time to eat, then back to the shop! Jim.
