Well, things slowed down here for the last 2 weeks. As noted in the previous report, I got the basic extension table together. Then the big 'ole Bradford Pear in the backyard decided to fall apart. Two 35'+ lower limbs broke off on different nights. I spent last weekend cutting them up, and cutting down what ever else I could safely cut. You see, the service line for my shop runs (ran) about 12' to the north of the tree's trunk. All the limbs were above that. I tried to find a way to tie a rope on to the top, then attached to the riding lawn mower, so I could cut and Glenna could pull the limb away from the lines...no way to safely get a line up there. So had to wait until last Monday to get the power company out to drop the line. Cut 4 of the remaining limbs out on Monday night, and the other 2 on Tuesday night. Of course, they both fell into other trees and stuck, making getting them all the way down a little more precarious, and a lot more work.
They are still all over the back yard. I've cut up about 15% of the limbs. This is going to take a while.
I took yesterday to go get supplies, and install the laminate. Came out pretty good. I used the little Hitachi fixed base router that was a rebate for buying the 10" slider a couple years ago. Worked great. That's a nice little router, especially for free! I test fitted it and got a basic alignment on it.
I need a chamfer bit to match the angle of the chamfer on the front of the table saw top/wings before it's finished, then seal the exposed oak, and poly the underneath and front edge where it will butt up against the wing. Need to decide if I'm going to drill 2 holes in the edge of the wing to suck the extension table up tight or not. I have decided, now
, that I should have doubled up the MDF on this particular edge to make it a little stouter. Oh well, I'm sure it will work. If worse comes to worse, I'll cut open a spot underneath and slip a fender washer and nut in to secure that edge.
And did I show the routed slots in the top of the cabinet before? Well, this is what they were for:
Very easy to adjust and supports the extension table very nicely. When I make my final adjustments, I'll screw into the sides through the angle iron and rear rail pieces. Yeah, I know, I still need some 1/4" ply to back the cabinet with. One of these days......
Hope this Sunday morning finds everyone rested! If so, come help me with this tree!!!
Jim.
