Sorry Greg, but the pics will have to wait, as the only camera I have right now that works is the one in my cell, and it is difficult to set up for a timer shot, nowhere to put a tripod
On to other things....
North wall cabs, I put slab door on them......
No pulls at the moment, and not the best doors, but they will keep the dust out of the cabs, and things will be more organized, so I think it is a win.
I was trundling around the Dungeon today, and I realized that I've got a fair bit more room now, nothing by the standards of a lot of other shops, but for me, the extra space
IS noticeable.
OK, on to the next little project.........
I wanted to make a rack for my Bessey clamps, I saw Glenn's step by step, but thought I could maybe do something a little quicker. Nothing against Glenn's set up, I think his is nicer than mine, but for me, this just plain worked, and worked well, I was done in about 45 minutes, maybe an hour....
First, I put two clamps side by side, the space between the bars was 29mm, so I cut some spacer blocks at 30mm.
I wanted to use my SCMS to do this, but cutting small pieces like this on the SCMS is NOT a very safe thing to do, unless you do it the right way.
I first put a space block, the same thickness of the piece I'm cutting, to give me space between the stop block and the saw.
Here is the stock to be cut.......
Now you have to hold the piece, but I'll NOT be using my fingers to hold it, NO WAY......
I just use a hold down block, this hold the piece in place, and keeps my fingers safely out of the way.
There, cut, nice and safe!
Now I've cut enough blocks to stack 3 of the 1.5mm thick pieces of plywood, which will be enough to support these clamps. Got to make sure that the blocks are tight against the bar, and square.
I just coat them with glue and then shoot a couple of brads into the blocks to hold them while the glue dries.
Here is the second block shot in place, make sure you shoot the brads near the outside on the first block, then closer together on the second block and finally back out near the edges on the third block.....
there the third block is shot in place.
Give the blocks some time to dry, and then put the quick and dirty rack on the wall somewhere.........
Nice and simple, very little math required
(Yes, I know that I need to remove all them stickers on the clamps.....
