So, How does that one actually work? It seems like it's more for 'standard' printers than anything else?
I'm guessing that it would basically 'extend' your usb connection over the LAN so you could run your Lightburn job remotely from inside?
The disadvantage I see with that is that when you are running the job, the only way to work with the laser is from your office.
Another option is to go with a raspberry pi and octoprint. Octoprint has plugins that allows it to work with laser engravers as well as 3d printers and CNC machines.
The way octoprint works is basically the Pi is a computer that you plug your engraver into via usb. It runs a server on it that you can connect to from your computer, your phone a tablet, etc...
So a work flow would be:
- Design your job in lightburn
- Export the gcode
- upload gcode to octoprint
- Go to the garage, setup things on the engraver
- Start the job
- Monitor it from the tablet or office computer.
Another option might be to just get a cheap laptop to put a second copy of lightburn on in the garage and use that to run your jobs.
That being said, What I'm running now is a computer in the shop directly controlling the CNC with the laser on it, as well as my C02 laser. In nicer weather, it's nice to just spend time out in the shop and having a computer out there can be handy.
