I also have a DeWalt 735 and have had it for about 15 years. It replaced a Delta that had severe snipe problems. The snipe that I get with the 735, when I do get any, is just a faint line and a few thousandths difference in thickness. A ROS and 150 grit paper takes it out to invisible in just a couple of quick passes.
I do my planning outside my small shop in the parking area. To make this heavy planer easy to move in and out of the shop, I quickly decided that the DeWalt stand for it would not work for me, and sold it. I bought a hand truck style folding Miter Saw / Planer stand and attached the 735 to it, using a piece of 3/4 cabinet birch plywood as an adaptor. The rails of the stand are intended for a miter saw mount and not the same spacing as the mounting holes of the planer, but this DIY adapter solved the problem.
When not in use, the planer on this stand sits upright like a hand truck in the corner of my shop requiring only a few sq ft of space. When I need to use it, I tilt it back and roll it out of the shop much as you would a hand truck with a stack of boxes on it. To set the planer up for use, I lay the handle of the stand down on the ground, and then lift the planer and top part of the stand up until it locks in the up position. Gas springs in the stand assist in lifting the weight of the planer, so this is easy, even for my 79 year old broken body. There are 2 up position levels to choose from. I then attach my DeWalt accessory hose / barrel cover to a plastic 60 gallon barrel that I keep upside down behind my shop and plug the planer in. When the planning is completed, the stand folds down into the hand truck configuration, and I can lift the main handle and wheel the planer back into my shop to again store it upright in the corner of the shop. Although my stand is a Delta, the improved DeWalt stand is nearly the same, but with a few improvements. Expensive, but worth every penny for it makes handling, moving, and storing my DeWalt 735 easy for even this 79 year old heart patient with metal knees.
www.amazon.com/DEWALT-Miter-Wheels-DWX726-Yellow/dp/B0066N7C74
DeWalt no longer offers the hose / barrel cover accessory that I have, and you really need some way to collect the chips if you don't already have a big cyclone chip collector in your shop, but under the B & D name they do offer a leaf collector hose and barrel cover that appears to be identical to the DeWalt accessory that I have, so it might be worth looking into to see if it will work for you. The part that I'm uncertain about is the connector fitting for attachment to the 735 planer. The hose and the fabric barrel cover appear identical to what I have.
www.blackanddecker.com/products/lawn-and-garden/batteries-and-accessories/accessories-and-attachments/leaf-collection-system-for-all-corded-blackdecker-blower-vacs/bv-006l
Do not expect a Shopvac and 5 gallon container to be able to handle the output of the 735 planer. It will fill the Shopvac in less than 2 good passes of an 8' board through the planer, if it's hose doesn't plug up before that. The blower inside the 735 planer is quite forceful. As a test when I first got mine, I ran a 2' short piece of 2 X 4" through mine while it was sitting on my workbench just after removing it from the shipping box. The chips coming out of the planer hit the far wall of my shop about 15' away at almost the same level that they exited the planer. What a mess ! Don't do this !!!
