Leo Voisine
- East Freeetown, Massachusetts
Any thoughts on going from copper to pex using sharkbite fittings
Yes, that is a good point. In full disclosure, I have only used them for emergency repairs where I either had a valve that wouldn't fully shut off and couldn't sweat the fittings due to water, or emergency repairs of similar issues with sweating them. My last use was on our outdoor water boiler circulation system to our radiators in the dead of winter and an leak was occurring on a radiator my wife's grandpa put in the outdoor greenhouse. I ended up by-passing the radiator inside the basement going copper >> Pex >> copper. Draining that part of the system would have taken a few days and the temps of the water at that point were only about 130*F.When the solder/crimp parts to do it are so economical, and an adapter that solders to the copper and then crimps to the Pex is certain to be permanent, why spend extra to go with something that has even the slightest amount of doubt attached to it?
Yeah there's pex B with the crimp fittings that you basically have to go up a line size for the same flow and there's pex A with the expansion fittings that you can run same size as copper. Reportedly A leaches a bit more (at least to start with) especially if you have chlorine/chloramine/chlorine dioxide in your water (in which case look for ASTM F2023 certification), and *might* be slightly more attractive to rodents than B, but A is also more flexible so it's more freeze resistant as well.If I use standard crimp couplers they chock down the flow.
If you take a look at how small the passageways inside the shower valves and heads are, you wouldn't worry about that slight restriction at the Pex/Copper joint fitting. I ran 3/4 Pex for a water header and then "T" down to 1/2 for individual appliance feed lines. I get full flow.I am looking into the newest ones of those so I can get full flow though the 1/2" lines to the shower. If I use standard crimp couplers they chock down the flow.
We have a mix of CPVC and older galvanized lines. Other than the main well lines coming in, I'll be replacing all of the supply lines with Pex. The shower that was added about 15 years ago is the only fixture that really has any real water pressure as all the final lines to everywhere else is plugged up in the galvanized pipe.I'm intrigued that you can use the sharkbite fittings with CPVC. My house is partially plumbed with CPVC and I live in its shadow as I know it can become very brittle with age and is therefore more subject to damage that other forms of plumbing. The one case where I had to attach new work to existing I used a glue on fitting to adapt to a threaded fitting for some flexible line for our water softener. Scared me and I was VERY careful.
