glenn bradley
- SoCal
Time to setup dad's bandsaw at my new shop. It is a windfall having a pair of these machines. Dad lived near the ocean and did little maintenance the last year or so.
First thing is to change the plug end to match my new 240v standard and put a large paddle on the switch.
I put a piece of sheet magnet over the lower dust port as I do not use this one.
The ocean does strange things to plastics and rubbers. The tires are shot. I have put urethane tires on while the wheels were on the saw. Dad had purchase some OEM tires that are much stiffer so I pulled the wheels.
You raise the motor to de-tension the belt on this model. Here's my handy motor jack; a couple of boards and a quick-grip spreader.
The tires get heated for about 10 minutes.
You then wrestle them on wishing you had some help. A couple of clamps and a large round shaft screwdriver help out here. As long as I had the wheels off I checked for coplaner. This machine was real close but, I'm here so why not spend an extra ten minutes. I use some shim stock behind the spacer that the upper wheel bearing rests against.
Now I just wait 6 hours (per the instructions) for the tires to fully cool. Then I'll slap a blade on it and do the alignment process.
P.s. Speaking of the ocean doing strange things to plastics. The mobile base wheels self destructed. I put metal replacement wheels on my other bandsaw and have a set for this one as well.
