glenn bradley
- SoCal
I don't usually do shop tours because it will destroy the illusion that I am neat and organized. No clean up here, just the slow degradation that comes from being on light duty orders from the doc for a little longer. I'll call the tablesaw's operator position the front of the shop. That being said this is the view toward the back right corner from the back left.
Along the left is some vertical lumber storage which we'll come back to and a commercial cabinet that I re-did the interior on. It has shelves and pullouts that fit my plastic storage products of choice and various other items. the pullouts keep things from getting lost in the back.
Continuing to the back right corner there is the panel shorts bin although it holds things other than panel pieces . . . sigh . . the best laid plans. The small bandsaw is waiting to go on a base. That and other flotsom makles this look more cluttered and space restricted than it usually is.
If you walk up to the shorts bin and turn left you are looking toward the front right corner of the shop. The fan moves around to where I need it. The plant pots are just visiting.
To the right is my drill press which we'll revisit later. Stepping forward there is the large bandsaw. On the cleat wall to the left of the bandsaw is the bandsaw "stuff" organizer. Everything you need to change blades, fence and miter gauge storage and so forth. The bandsaw is on a mobile base and can roll forward for long resaw work.
If you step away from the large bandsaw area here is a sort of overall view of the cleat wall.
I build bases with drawers or build drawers into almost everything. The spindle/disk base holds all that sander's paraphernalia. A built in mobile base moves this guy out for any larger work.
cont'd . . .
cont'd . . .
