- Springfield, Missouri
We bought an automatic cat food feeder and had been testing it out as we go out of town time to time. I tried to keep it under an end table on the porch last time, it worked for a few days, but eventually Trash panda won. He got it out from under the table and the lid off.
Surprisingly it didn’t incur any real damage, just a few teeth marks around the lid.
I decided to build an enclosure for it today. I wanted the base large enough they couldn’t easily tip it over, cover the feeder slides so they couldn’t knock them off, and still have the bowls removable for cleaning.
I first outlined the feeder on the base, then squared out space around the outline to frame out the walls, just 1x2 pieces for the corners and some left over sheeting from the guest cabin for the walls and base, nothing fancy, but plan to paint it.
I got some help on the project from Sissy.
I hot glued some rubber feet on to keep the from sliding it on the porch.
Added the hinges and a clasp.
Won’t leave the table over it, but may add a landscaping block or two for extra anchoring.
I have a power cable come out the window for it, but if that gets disconnected or damaged, the feeder still runs on 4 D batteries, once programmed.
