- Constantine, MI
Sorry, not a lot of play-by-play on this one. I've been so busy between the shop, a new job, and helping to care for Fletcher that whatever time I have to work in the shop has to be devoted to getting things done rather than take pictures.
This is another sofa table based on the designs of Darrell Peart. This time in cherry. I made a lot of changes to the construction methods on this one to accommodate the use of dominos. In fact, every joint is a domino joint.
I did take a few pics of the breadboard end construction as using dominos here is a real departure from traditional methods. The two dominos in the center are glued at both ends, the outer four are glued at one end and allowed to float in oversize mortises on the other. 3" Long panhead screws pull everything tight. The outer screws have elongated holes to allow for movement. So much easier than the traditional long mortise and tenon. The screw holes will be plugged with 3/8" square ebony plugs.
Finishing starts today. I'll be using 3 to 4 applications of Livos oil.
