Family Woodworking
Go Back   Family Woodworking > General Woodworking Area > Jigs and Fixtures
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Jigs and Fixtures No, not dances and lighting...this forum is for discussing the shop accessories we build to make life easier and safer.
Reply
Thread Tools Display Modes
  #1
Old 02-09-2008, 06:58 PM
Niki Avrahami's Avatar
Niki Avrahami Niki Avrahami is offline
In Memoriam
Cross-cut sled - different way
Good day
I would like to share with you my method.
First, check the alignment of the blade to the miter slots.
The idea is very simple, I make part of the sled, cut the kerf and refer to it as a reference point (or line) to position the "Back Fence" square to the kerf by "locking" everything together.
I discovered that the plastic drawing triangles are very, very accurate, and I use them to locate the fence (actually, as you will see, I'm using the shop-made triangles that were "copied" from the plastic one).
By cutting the Runners 1 mm narrower than the miter slot width, it's very easy and fast to cut the runners and, I think, will eliminate any binding due to expansion with humidity changes.
My table saw is different and has only one miter slot, so I made some kind of "fiction" miter slots for the guys with the "normal" table saw...(I think everybody except me)
It took me around 1½ hours to make it (including 148 pics), so I assume that it should take you 2~2½ hours, considering that you have to prepare the parts (I used scraps from around the garage).
Regards
niki
Reply With Quote Share on facebook
  #2
Old 02-09-2008, 06:59 PM
In Memoriam
  #3
Old 02-09-2008, 07:00 PM
In Memoriam
  #4
Old 02-09-2008, 09:30 PM
Mike Gabbay Mike Gabbay is offline
Nice method Niki. I'm in need of new sled, I'll give that a try.
  #5
Old 02-09-2008, 10:31 PM
Alan Schwabacher Alan Schwabacher is offline
This looks like a very good method. A similar method that is not quite as accurate, but a little bit easier to do since you don't need a kerf-thickness shim is as follows.
Attach a long scrap to the bottom of the sled before you cut the kerf, so that you cut the long edge of the scrap away. Now you have a well-anchored edge to hold your square against while you position your fence. Then remove the scrap. This only allows you to use one square to align the fence, rather than Niki's two, but it works pretty well.
  #6
Old 02-10-2008, 10:24 AM
Chuck Beland's Avatar
Chuck Beland Chuck Beland is offline
Niki,
You are a true master of invention. Thanks for all of your help.
Chuck
P.S. Did you get my PM on the tutorial I made after you gave me some instruction on how to do it?
  #7
Old 02-10-2008, 07:03 PM
In Memoriam
Thank you so much
Chuck
The only PM that I received from you was that it looks different on your PC but you managed to make it.
My PC is the old...ummm, antic Windows 98.
A few days ago I installed it on my wife's Windows XP (they always have the best) and it does look different on her PC.
Regards
niki
  #8
Old 02-10-2008, 08:52 PM
Niki,
I showed you the thing I sent a friend it was on Thompsons gouges & I added words like you showed me to do just like on your tutorials.
Thanks for the help your directions were perfect. I use Windows XP version.
Chuck
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
