Chuck Ellis
- Tellico Plains, Tennessee
I have a 2007 or 2008 model of a JET 1442 lathe with the Reeves unit.... Last week I broke the belt and had to replace it today... always a chore replacing the belts and pulleys on this unit.... after I got the belt installed and moving I discovered that the on/off switch doesn't turn on the motor... I got it to going one time, then nothing, no hum in the motor so I'm pretty sure the switch is defunk.... it's the original switch on a lathe I've used consistently since 2008.
Question is, how hard is it to change the switch and are there any tricks I should know about before I order a new switch...
I'm pretty sure it a rocker switch....most of the switch wire appears to be inside the head stock, which has little to no access.
Also my head stock seems to be frozen in place on the ways, cannot swing it around for access and currently it sits with the back to a wall...
I can probably swing the headstock end of the ways out so I can get behind it, but I have a cabinet built under the ways that adds a 100 ++ pounds
to the weight....
to the weight....
